EMISTP Configuration Example is an example of EMISTP.
By default, all ports added to a user-defined STPD or STPD s0 are in dot1d mode, unless otherwise specified.The following commands configure the switch located between S1 and S2:
create vlan red configure red tag 100 configure red add ports 1:1-1:4 tagged create vlan green configure green tag 200 configure green add ports 1:1-1:2 tagged create vlan yellow configure yellow tag 300 configure yellow add ports 1:3-1:4 tagged create stpd s1 configure stpd s1 add green ports all emistp configure stpd s1 add red ports 1:1-1:2 emistp configure stpd s1 tag 100 enable stpd s1 create stpd s2 configure stpd s2 add yellow ports all emistp configure stpd s2 tag 300 configure stpd s2 add red ports 1:3-1:4 emistp enable stpd s2
